Problem With 550 at Lake Powell
  • kodiak
    • Jan 2014
    • 157
    • Salt Lake City UT
    • 2021 G23 ZZ8 2014 G21 550.(Sold)
    So my 550 with about 120 hours had a few hiccups this last week at Lake Powell.
    So two times over the last week at lake Powell my engine came down to idle RPM,
    when on the back to dock setting not sure if this was a coincidence?
    The first time it came down to idle and sputtered a bit then was fine.
    The Second time it came down to idle and sputtered and stalled.
    I let it sit for a few minutes and started it back up and it worked fine.
    Is this a symptom of bad Gas?
    I only used shore gas at 91 octane. Went thru about a tank and a half.
  • JoeA
    • Jun 2014
    • 808
    • Chickamauga Lake TN
    • 2015 G23 550
    water in gas?
    2015 G23 550
    2013 Malibu 22MXZ
    • Abarkerslc
      • Mar 2009
      • 14
      • Salt Lake City
      • 2014 G23 550hp
      Did you pull glass of your houseboat? If so is it possible that it was lower octane
      • kodiak
        • Jan 2014
        • 157
        • Salt Lake City UT
        Only used gas from the shore pumps that are 91. Filled the boat with it and took 30 gallons in cans.
        • Abarkerslc
          • Mar 2009
          • 14
          • Salt Lake City
          • 2014 G23 550hp
          Ask croft to take a look, I am sure it's nothing just to be safe.
          • kodiak
            • Jan 2014
            • 157
            • Salt Lake City UT
            Took it to dealer and they verified it didn't throw any engine error codes, so they replaced both fuel filters and we will see if it happens again.
