Problem with 2006 Sante
  • Jhgoosefan
    • Jun 2015
    • 6
    • Sandy, Utah
    • 2001 Pro Air
    I just bought a 06 Sante, took it out yesterday for the first time. Starts and idles great. After about 10-15 second under power the boat loses all RPM and will only idle. It will stay this way until I turn the boat off then I have full power but will do the same thing. There were two time that I got the boat to run for 10-15 min without doing it but I have no idea why. Any ideas or advice would sure be helpful?
  • jkallen21
    • Jan 2013
    • 399
    • United States
    • 2006 Super Air 220
    when you lose RPMs, the boat is still running and in gear, right? But it won't go anywhere and pushing throttle does nothing? If so, I have the same boat and the power cable came loose from the kick plate behind breakers at driver's feet. Disconnect battery and take a look - you should be able to verify without removing the kick plate. If the nut is still there, tighten it down and you're good to go. Hope that's it.
    • jkallen21
      • Jan 2013
      • 399
      • United States
      Any update?
