I have a 2000 SAN 210 with the GT40. Im stupid and apparently didnt get all the water out of the engine over the winter and froze and cracked the block. Question is, will a Ford 351W block work with all the PCM manifolds and such or is there a specific block they built for PCM? Thanks in advance.
Any 351W block should work for you. Nothing special was done for PCM, they were just regular 351W blocks and then PCM marinized with their cam, fuel system, etc. Good luck!Shawn
2012 Blue Metal Flake SAN 230
I did a similar stupid thing years ago but instead of the engine block it was the manifolds. Go easy on yourself and good luck.2013 G23 450 with NSS (175hrs) and still have the original prop
2010 SANTE 230 343 (280hrs)
Originally posted by s_kelley2000Any 351W block should work for you. Nothing special was done for PCM, they were just regular 351W blocks and then PCM marinized with their cam, fuel system, etc. Good luck!1990 Ski Nautique
NWCT
