2012 Sport 200V Zero Off Question
  • Gprsh924
    • Mar 2015
    • 6
    • Chicago
    Having an issue with the zero off. When we go through the process of starting up the boat, when it has been sitting overnight, the zero off system will almost never start up/initialize on the first try. Also, no power will be going to the radio either. If we then turn off the boat (hitting the off button until everything is completely shut down) and then start things back up, both the radio and zero off get power and everything works fine. Any idea what could be causing this?
  • theskunk
    • Oct 2014
    • 232
    • Stafford, VA
    • 2006 sv-211
    Does the boat fire right up? Do you have a single or dual battery system? Does this one have the Linc system? or just standard gauges?
    • Gprsh924
      • Mar 2015
      • 6
      • Chicago
      Single battery, standard gauges, boat fires right up. We did have a dead battery 2 weeks ago and I was using the boat this weekend and noticed that this problem seems to have gone away. Maybe it had something to do with the low power/dead battery. Since we did the full charge it hasn't had the problem.
