Belt Squeal
  • Cumby
    • Feb 2014
    • 16
    • Simpsonville, SC
    • 1999 SN GT40
    Belt Squeal
    I had a new belt put on my 99 SN GT40 couple of months ago. Only had it out maybe 4-5 times so far. I'm getting a squealing noise at cold starts for 5-10 seconds or so and when revving the engine fast. I'm assuming it's the belt. Should I just try tightening it a little to see if this resolves it? Where do I tighten it and how do I make sure I don't over tighten?
  • a0128
    • Jan 2014
    • 423
    • Lake Oswego, OR US
    • 1999 Pro Air Nautique
    Get new belts http://www.nautiqueparts.com/beltsetfordengines.aspx
    Download engine manual http://www.planetnautique.com/Correc...T-40Manual.pdf
    Belts should be tightened so that there is 1/4" of deflection.
    • kend
      • Oct 2013
      • 193
      • DFW, Texas
      • current 2001 Air Nautique previous 1988 Sanger DX
      I think it's the alternator bracket that pivots to tighten on that boat (top of port side -loosen two bolts.. pivot bolt and bolt on slide bracket 9/16" if I remember. Pull alternator to tighten belt and re-tighten bolt on slide while pulling alt tight). Probably a new belt getting broken in and got a little loose. Hopefully it's just the belt and not a metalic squeaking noise that happens when a pulley bearing is going out because of over tightened belt
      Ken
      2001 DD Air GT40
      • Cumby
        • Feb 2014
        • 16
        • Simpsonville, SC
        • 1999 SN GT40
        Sounds easy enough.
        Isn't there a way to check the proper tension on the belt by pushing on it to see how much it gives? Not sure how to keep from over tightening?
        • Cumby
          • Feb 2014
          • 16
          • Simpsonville, SC
          • 1999 SN GT40
          Sounds easy enough.
          Just found it. Press half way between the alt and water pump pulleys and you should get 1/4 " play in the belt.
          • kend
            • Oct 2013
            • 193
            • DFW, Texas
            That's not much, I assume a0128 means 1/4" in each direction. Auto parts stores sell a spray can "belt dressing" -a sticky substance that is supposed to stop belts from squeaking by giving them more traction against the pulley surface.
            Ken
            2001 DD Air GT40
            • Cumby
              • Feb 2014
              • 16
              • Simpsonville, SC
              • 1999 SN GT40
              Yeah, I thought about trying some of that. May pick up some of it to try among with tightening a little too.
              • Cumby
                • Feb 2014
                • 16
                • Simpsonville, SC
                • 1999 SN GT40
                Checked the belt and it was very loose. Could spin the alternator easily. Got it a tight as I felt comfortable using a wrench as lever, but I can depress it more than a 1/4 ". Seems tight and like it should be enough. I would hate to over tighten it.
                • theskunk
                  • Oct 2014
                  • 232
                  • Stafford, VA
                  • 2006 sv-211
                  How big was the wrench? Generally speaking, you're not going to get it too tight without a rather large crow-bar, and when they say 1/4 inch in either direction, they really mean between there and a half inch. If it still squeaks at you, tighten it more.
                  With that engine, you do *not* want it too lose, as over time the alternator, which has a bracket that is designed to handle that tension, *can* actually come out of line with the rest of your pulleys and you'll start going through belts very fast.
                  • Cumby
                    • Feb 2014
                    • 16
                    • Simpsonville, SC
                    • 1999 SN GT40
                    About 12 ". I'm pretty sure it's between 1/4 and 1/2. So if no more squealing can I assume it's tight enough?
                    Is there an adjustment on the other belt. It has more give to it when I push on it, but don't know if that's normal?
