Obtaining engine hrs 2000 san
  • 2000san
    • Sep 2012
    • 25
    • Diana
    • currently 2000 SAN
    How do I go about pulling the current engine hrs on my 2000 super air nautique? It's a 5.7 PCM engine. Thanks for your help
  • Quinner
    • 2246
    • Correct Crafts
    If it is a Chevy Apex as you indicate you "should" be able to pull hours from the ECU. If you have perfect pass hours should be kept there as well however unless it was installed new and never updated those hours may not be 100% accurate
    • 2000san
      • Sep 2012
      • 25
      • Diana
      Yes it's chevy apex. So to connect to the ecu ill need a compatible communicator I guess? Also I know the perfect pass was installed by the previous owner and not new. I've never seen a "total hrs" setting on the perfect pass but am almost 100% sure it's not accurate
      I'm thinking about selling my boat and am wanting to advertise accurate hrs.
      • 2000san
        • Sep 2012
        • 25
        • Diana
        Anyone know of a link or manual to do this? Thanks
