Ballast pump fills but won't empty when light is flashing
  • Silver Surf
    • Sep 2013
    • 68
    • Smyrna
    • 2006 SANTE
    I have a 06 220 SANTE. Today my ballast pump started acting up. Starboard fills but won't empty. I checked all the breakers and still no luck.
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    Did you take off the cover and verify it spins both ways?
    • d_nodixon
      • Sep 2008
      • 475
      • Hammond, LA
      • 2013 SAN 230
      Is the sending unit working correctly? If reading empty, or unplugged it will not empty. Unplug and insert a jumper wire to test
      Sent from my VS985 4G using Tapatalk
      2013 SAN 230
      2006 SSN 210 (SOLD)
      • Silver Surf
        • Sep 2013
        • 68
        • Smyrna
        • 2006 SANTE
        My first reaction was to change the impeller. I keep a spare on the boat. When I popped the cover off, I had the wife try the switch in both directions.
        d_nodixon, This makes sense, I can here the switch/relay in the dash area when I hold to empty but the pump doesn't make a sound. The starboard side level sensor & gauage has been a little lazy recenlty. I will try that this evening.
        • theskunk
          • Oct 2014
          • 232
          • Stafford, VA
          • 2006 sv-211
          Do you piggyback? I'm wondering if your tank could have been sucked down enough to bend the sending unit such that it thinks it's empty when it's actually not.
          I second the vote for the jumper test, and also see if you can scope your sending unit and make sure your float moves freely.
          • Silver Surf
            • Sep 2013
            • 68
            • Smyrna
            • 2006 SANTE
            Yes, I do piggy back. Float should be easy to get too.I think its under the carpet/board on the startboard side with 2 screws holding it down.
            • Silver Surf
              • Sep 2013
              • 68
              • Smyrna
              • 2006 SANTE
              d_nodixon nailed it! It was unplugged. I'm guessing something stored in the compartment must have pulled on the wire.
              Thanks!
              • d_nodixon
                • Sep 2008
                • 475
                • Hammond, LA
                • 2013 SAN 230
                Glad that worked for you!
                2013 SAN 230
                2006 SSN 210 (SOLD)
