Aluminum GT40x heads on 95 SS
  • workky
    • Nov 2003
    • 120
    • Lake Allatoona
    • Marietta,Ga
    • 1995 SuperSport
    just curious,
    I installed a new set of aluminum heads on our 95 SS. The orginal heads had a lot of ground wires running to them. Do I need to run the grounds the same on the aluminum ones? Im going through ignitiin modules for some reason after the swap, cant figure out why orther than maybe a grounding issue.
  • kend
    • Oct 2013
    • 193
    • DFW, Texas
    • current 2001 Air Nautique previous 1988 Sanger DX
    Originally posted by workky View Post
    just curious,
    Aluminum should be a better ground than the originals, running the same should be good for ground
    Ken
    2001 DD Air GT40
    • workky
      • Nov 2003
      • 120
      • Lake Allatoona
      • Marietta,Ga
      • 1995 SuperSport
      That's what I thought, Thanks
      Im thinking I got some crappy aftermarket ignition modules, im going with motorcraft
