2007 PCM ZR6 engine won't start
  • CanadaNautiqueGuy
    • Aug 2014
    • 54
    • Calgary, Alberta, Canada
    • 2002 196 Open Bow
    The engine will turn over and fire briefly, but won't run. Fuel pumps sound like they're running. Fuel comes out of the FCC overflow. I don't have a pressure gauge, but when I push the fuel pressure gauge nipple, fuel squirts out. It's not the cut off switch because when I active the switch, the engine turns over, but won't fire. Any ideas?
  • bscott
    • 188
    • Bolingbrook, IL
    Try disconnecting/reconnecting your safety lanyard.
    • CanadaNautiqueGuy
      • Aug 2014
      • 54
      • 2002 196 Open Bow
      Thanks, already tried that.
      • Paxdad
        • Mar 2013
        • 775
        • Cumming, GA
        • 2008 210 SANTE
        Remove the distributor cap and check for corrosion.
        2008 210 SANTE
        • BoardSkier
          • Jun 2014
          • 252
          • Lake Anna, Virginia
          • Air Nautique 226
          Make sure you have a strong battery. It may turn the starter but not enough for ignition. We've run ours down in a cove. Turned the engine but wouldnt start. Switched to battery 2 and fired right up.
          2005 Air Nautique 226
          Supra Comp (prior)
