Bow light / anchor light 2007 211
  • littlejess
    • Dec 2014
    • 5
    • Hartwell
    • 2006 SV 211 1982 2001
    Anchor light will not work, does it work simultaneously with the nav lights , then alone as well?
  • nukemustang
    • Sep 2014
    • 410
    • Summerville, SC
    • Current Boat: 2018 GS20
    It should work in two modes, one "underway" which will have the bow's red and green running lights and the white "stern" light (on the tower) illuminated. the other is "at anchor" which should just illuminate the white stern/tower light. I have had this pounded in my head as a Surface Warfare Officer in the Navy. :-)
    http://www.sailingissues.com/navcourse10.html
    • theskunk
      • Oct 2014
      • 232
      • Stafford, VA
      • 2006 sv-211
      on your keypad, you push the button in a short-press fashion to turn on nav (under-way), and then a longer-press, similar to the ballast pump reversers, for the "at anchor" function.
