SeaDek flooring for a 2005 sv211
  • Rockymtnsurfer
    • Nov 2017
    • 404
    • Steamboat Springs Colorado
    • 2003 210 SANTE
    Originally posted by rdwynn View Post
    I'm looking to the same install this spring. Thanks for all the info. How did you install on the swim deck? Do you remove the black plastic non-slip material or install over the top?
    https://www.planetnautique.com/vb5/f...orm-conversion
    • homer12
      • Feb 2016
      • 584
      • Indianapolis, IN
      • 2004 SV211 TE
      You must absolutely remove the old black sano pads. If you don’t you’re wasting your time and money. Peel them off, use a plastic putty to get them started if necessary. Mine came right off. Then use an old rag and acetone to clean up the sticky residue. You may need the plastic putty for some of that too. Should take less than an evening or two.
      • pokesgrad02
        • Aug 2012
        • 170
        • Lenexa
        • 2018 SAN 230
        Did you guys fill holes from the snaps you removed on floor? If so what with?
        • homer12
          • Feb 2016
          • 584
          • Indianapolis, IN
          • 2004 SV211 TE
          I didn’t see a big need to fill them so no. If you feel inclined I’d use silicone. If anyone else filled them I’d be curious as to why...
          • Nikkia311
            • Apr 2019
            • 1
            • Indianapolis
            • 2006 Nautique SV211
            Originally posted by cjacob06 View Post
            Heres the template i had Seadek build for me on my 2005. Everything fits perfectly as you can see from the linked post above. Many of the templates floating around are for the newer model years that dont have cupholders on the rear step off the walk through. There's also a couple different versions of the transom pieces. I emailed Seadek directly and they are very helpful with the templates they had for the SV-211 and we went back and forth to build a hybrid template for all the pieces (Swim Platform, Transom and Interior are all available as standalone kits if you want). I measured each one and this is what we arrived at that fit my boat.
            Keep in mind the process is 10 days to build the kit once you sign off on the final template. If you start from whats attached and it works for you, that will save you the week or so of back and forth I had with them. Once you sign off on it, there's no turning back if it doesn't fit so I was careful to measure everything.
            Installation was really easy after you get the hang of it. I spent more time making sure the floor was spotless in between each piece than I did actually sticking it down.
            Acetone and a green scrubby pad worked the best for me as far as removing residue left from the SANO pads and my dry-rotted snap out carpets.
            Hello!
            I’m in search of a template for 2006 SV211 Seadek. Can anyone help me out? I see the one attached but I can’t open it?
            Thanks!!
            • Gwojcik7
              • May 2016
              • 25
              • Finger Lakes, NY
              • 2007 Super Air Nautique 220 Team Edition
              #21
              I would suggest GatorStep over seadek. I tried getting some info from seadek and they wouldn’t call me back or help. I was able to work with GatorStep to get a custom design done with the nautique logo in the middle and it looks amazing. Pricing is the same also
              • mikenbike211
                • Sep 2016
                • 447
                • New York
                • 2021 G21 2019 GS22 2017 GS20 2008 SV211 1990 Sport Nautique
                #22
                Originally posted by Inmikes View Post
                does Seadek cut flooring for a 2005 sv211? I would like to get rid of the carpet and install that flooring.
                I would be happy to buy your (or anyone’s) little piece of carpet that is on the first step leading out of the boat.
                • Quigs4
                  • May 2022
                  • 1
                  • Meridian MS
                  • 2005 210 SAN
                  #23
                  I have a 2005 SAN 210, looking for a flooring template in sea deck or something similar
