Install underwater lights
  • Edge
    • Jul 2015
    • 4
    • Calgary
    • 2009 Super Air Nautique
    Just puchased some SeaBlaze X underwater lights today.
    Is my 220 prewired for underwater lights ? There is a switch in the panel but boat is at lake so I can not check if there wires near the transom of the boat.
    As anyone have experience installing underwater lights using the swith pad in the boat ? thanks
  • Paxdad
    • Mar 2013
    • 775
    • Cumming, GA
    • 2008 210 SANTE
    I would say that based on the year of you boat it is not pre-wired for UW lights. However, you can use the 12 volt switch on your dash. When I installed my UW lights I put in a separate switch. There was a recent post in this section where the member used the dash switch for his LED interior lights and if I recall there is a number 11 on the junction box under the dash that you plug into.
    2008 210 SANTE
    • Silver Surf
      • Sep 2013
      • 68
      • Smyrna
      • 2006 SANTE
      I have a 06 220 SANTE. I used the navigation light switch on the panel for 2 lumitec seablaze. In the engine compartment near the transom there is a plug for a nav light in the factory harness. I got the male end off ebay. I haven't had any issues.
      • Paxdad
        • Mar 2013
        • 775
        • Cumming, GA
        • 2008 210 SANTE
        Silver,
        That is good to know. I am going to look for the plug tonight when I get to the boat.
        2008 210 SANTE
        • shag
          • 2217
          If you have a switch for U/W lights then you probably can wire it to that switch. You will have to obtain a factory pin out schematic for your particular boat. I did this on a 2009 230 and just had to fabricate a 'pin' to fit.
          • Silver Surf
            • Sep 2013
            • 68
            • Smyrna
            • 2006 SANTE
            I think this was the plug I used for the OEM harness
            http://www.ebay.com/itm/380600460631...%3AMEBIDX%3AIT
            • Edge
              • Jul 2015
              • 4
              • Calgary
              thanks very much I will check for a plug as soon as get back to the lake
