What type of trans. fluid for (1990 sn) 351ford
  • SEEN-NC
    • Oct 2003
    • 19
    • CHARLOTTE, NC
    I tryed to look back through all the old forums but no luck...
    need to change fluids before I put back in the water..
    1990SN Ford 351
    Also is there another way of getting out of the trans. other than the dipstick??
    Sean G.
    Mountain Island Lake, NC
  • TRBenj
    • 1681
    • NWCT
    RE: What type of trans. fluid for (1990 sn) 351ford
    Going from memory...
    PCM recommends straight 20W. Valvoline is the only brand that I could find locally.
    There is a drain plug on the bottom of the tranny, facing toward the motor. However, its a real bear to get to. Using a pump with a tube small enough to fit through the dipstick hole is much easier.
    1990 Ski Nautique
    NWCT
    • Bremsen
      • Jun 2005
      • 61
      • Charlotte, NC
      Here you go:
      http://www.planetnautique.com/index....iewtopic&t=827
      Maybe I'll see you out this summer....we're out on MIL regularly.
      88 Ski Nautique
      • ccskier16
        • Nov 2003
        • 92
        • Hartland, WI
        • 2006 Ski Nautique 1974 Skier 16 1991 Ski Nautique, former
        I have found Citgo/Mystik 20W through out Wisconsin. But that really doesn't help you. PCM now recomends using Dexron in all their transmissions. So if you can't find 20W, Dexron would be a good easy find. I haven't made the switch but if you do, change it a couple of times to make sure you get all the 20W out.
        • SEEN-NC
          • Oct 2003
          • 19
          • CHARLOTTE, NC
          thank for the help
          thank for the help
          Look for the Yellow 1990
          • nch20skier
            • 167
            • North Carolina
            RE: thank for the help
            I always ran mobil 1, 5-20 inmy '83.
            Look for the Black/Purple Sport. I am out on some Fridays either in the sport or footing on the white/red barefoot nautuque
            88 Barefoot Nautique
            05 206 Team
            • nch20skier
              • 167
              • North Carolina
              I have seen a turkey baster used previously.
              05 206 Team
