2015 210 linc error
  • lucky7t
    • Mar 2011
    • 1306
    • Oklahoma
    • 2015 SANTE
    2015 210 linc error
    Had a strange issue this weekend and wondered if others would try this and see if you get the same error
    1. Start boat and select back to dock as user.
    2. Turn on speed control
    3. Kill boat
    4. Start boat and when prompted "Back to Dock" "yes/no" select no
    5. Then push music button
    When I do this it glitches the linc and goes crazy. But if I select yes in step 4 above it works fine
    Current Correct Craft Boat
    Correct Craft Boats Owned
  • SANonTellico
    • Aug 2014
    • 301
    • Tellico Lake, TN
    • 2022 GS22
    My Linc system (2015 210) showed several bad screens, dealer flashed it and it's been perfect since.
    Previously: 2015 SAN 210
    • shag
      • 2217
      This is why I don't care for the linc (imo only).. It's cool and all, and does pretty awesome things, but when it goes - you have nothing.... If I am correct.
      • Dandy21
        • Jun 2014
        • 159
        • Minnesota
        Had an issue with Linc on our 2014.if When switching sources on the stereo it would lock up. We unplugged the harness from the stereo for the day and all was good...assumed the stereo needed to be replaced. Dealer said Nautique said a software update was all that was needed. I didn't buy it but was not provided a choice. Turns out I was wrong and they were correct. Only have 25 hours on it but it has been trouble free since. Most likely the software flash will be the answer. Good luck.
        • lucky7t
          • Mar 2011
          • 1306
          • Oklahoma
          • 2015 SANTE
          Yes everything was not working when it froze. I'll ask about the update.
