Misfire on 2008 SV 211? Causes?
  • ksuich01
    • Jul 2009
    • 29
    • Greenville, SC
    • 94 Ski Nautique 98 Ski Nautique 2008 SV 211 2017 GS 22
    Question for the group... I have a 2008 SV 211 with 343 Engine and GPS Speed Control. Boat runs great, but I have noticed if I am traveling above 25 MPH and then ease off the Throttle to ~ 23 MPH the engine seems to Misfire and run a little "rough"? As soon as I either decrease or increase the speed the misfire goes away.
    Speed Control is Off, and issue has not seem to get worse, I just wander if it is something simple.
    Any ideas what may be causing the misfire?
  • nukemustang
    • Sep 2014
    • 410
    • Summerville, SC
    • Current Boat: 2018 GS20
    Have you ever replaced the cap and rotor? I know on my 07, I just replaced it and it was full of corrosion, but this could cause cross-firing or miss firing. start simple.
    Tim
    • theskunk
      • Oct 2014
      • 232
      • Stafford, VA
      • 2006 sv-211
      When was the last time your knock sensor was replaced?
      • ksuich01
        • Jul 2009
        • 29
        • Greenville, SC
        Thanks Everyone... I was thinking Cap/Rotor (maybe plugs and Fuel Filter) but didn't think about Knock Sensor? Do you have any more details on the Knock Sensor
        • theskunk
          • Oct 2014
          • 232
          • Stafford, VA
          • 2006 sv-211
          http://www.planetnautique.com/vb5/fo...-knock-sensors
          Sounds like you actually have two of them.
          One of these should be it. Don't forget you get 10% off at NP.com with the coupon code in nautiquejeff's signature.
