Adjustable driver's seat stuck
  • ScarletArrow
    • Jul 2005
    • 330
    • Ohio
    I have a 2012 SN200 (OB). The adjustable driver's seat seems to be stuck on the back half of the slide rail and won't pull as far forward as normally would. Seems like it's getting hung up on something, but when I poke my head underneath I can't see anything obvious. Anyone else have this issue? What should I look for before I go tearing into it?
  • ScarletArrow
    • Jul 2005
    • 330
    • Ohio
    It appears there's some kind of insert inside the slide rail that got out of position and was causing a hang up. I was able to pull the seat forward to its normal position with a little force (not much). Probably just needs some lubrication.
