06 sante 220
  • awesomelegs
    • Feb 2015
    • 6
    06 sante 220
    Boat won't start. It's not the battery, kill switch, neutral lock. Will sometimes start after repeatedly pressing start for no rhyme or reason. Engine clicks once when button presses but that's all. Everything has power.
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    Could possibly be the started motor on it's way out, or starter relay, check all connections from the battery's to the starter too
    1989 Sport Nautique
    • 8urchvy
      • Oct 2014
      • 176
      • La Verne
      • 2007 SANTE 220
      My boat cranked and wouldn't start. Turned out to be a corroded plug on the bottom of the back of the engine. I think it was the cam position sensor. I just unplugged it and cleaned it and all good.
      • Aebert2668
        • Oct 2014
        • 49
        • Atlanta
        • 2006 SAN 220 2006 18' Hewes Redfisher 1979 16' Duracraft
        Probably the starter solenoid, have a helper hit the start button and tap on the solenoid with a hammer at the same time. It should stop buzzing, clicking and start when hit by the hammer, make sure you are clear of all moving parts. You can also listen for a buzzing sound without the hammer, near the starter, while your helper pushes start.
