2008 SANTE Throttle Lag help
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    So for some reason my throttle went mush over the weekend. The lag between pushing forward and actually getting a response is almost 10o'clock. I know when I originally got the boat it was more between 10-11 for it to engage. Is there any adjustment ? I tried to adjust the ball and socket on the top of the engine but it's the slack before that even engages. And if I tighten it up at the ball n socket point, the throttle will not engage because it won't return to zero on the top of the engine. Any advice. ?
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    Not really advice, but I would wonder about throttle position sensor?
    http://www.nautiqueparts.com/tpsgm57-sensor.aspx
    • swatguy
      • 1631
      • 2008 SANTE 210
      Was able to adjust the back of the throttle and tighten it up just a bit. Pretty happy with the results. Not exactly as tight as I like but much better.
      • jkallen21
        • Jan 2013
        • 399
        • United States
        • 2006 Super Air 220
        Some of the 2006 and 2007 PCM engines were drive-by-wire and used a Potentiomter to actually drive the throttle. Not sure about 2008 - you can get the parts here: https://www.nautiqueparts.com/search...=POTENTIOMETER
        • Davidpsalt
          • Jan 2011
          • 92
          • Johns Creek, GA
          • 2018 GS22 2008 Ski Nautique 206 Limited Edition (Traded in) 1978 South
          The 2008 is drive by wire and uses the Poteniometer - I have a 2008 SN 206 and need the same fix - The part number is RA119005 and I just order one from Nautiqueparts as I am having the same issues - when I push the shift lever to the forward indent I then have to push the lever much further before the throttle begins to accelerate.
          Thanks!
          Dave
