Water in the Bilge?? Where is it coming from
  • boatnfly
    • Jul 2015
    • 21
    • North Haven, CT
    • 2007 SV211
    boat is in great shape now, looking to sell and upgrade
    • onthefly55
      • Aug 2009
      • 14
      • Nashville
      • 2005 216 team edition
      Boatnfly, did you r&r the complete rudder port or just the cracked play. I have a similar problem and am wondering how hard it is to remove the original and how hard to get a nice tight seal on a replacement
      • boatnfly
        • Jul 2015
        • 21
        • North Haven, CT
        • 2007 SV211
        I replaced both the cracked plate and port, as I bought them together. But I don't think you need to worry about a tight seal. Use lots of 3M marine sealant and new packing. It'll be fine. Easy fix however I had to remove the port ballast tank and lay on my back squiggle in and squiggle out of there to reach everything. It was a good AB workout getting myself out. Don't forget to buy new SS wire to safety wire the top rudder nut to the steering arm (VERY IMPORTANT). I also went to Harbor freight and bought a extra large (cheap) channel lock for both removing the packing nut and replacing. Other than the awkward body position it really was an easy job.
        • boatnfly
          • Jul 2015
          • 21
          • North Haven, CT
          • 2007 SV211
          Oh yeah don't tighten the new plate nuts too much. Let the 3M sealant do the sealing, if you tighten too much I think you risk cracking the new plate.
          • SuperAirIan
            • Jan 2009
            • 35
            • Alberta, Canada
            • 2001 SAN 8.2L Python, FAE, 2.3K, 4 Johnsons
            You can get safety wire by using .041 Stainless Steel welding wire. I had some serious leaking going on as well. Repacked the rudder with GFO. Still leaked. This Spring I replaced the consumables in the PSS drip-less. Still leaked. I then noticed that ALL the hose clamps around the back half of the motor/V-drive were "loose". Tightened them all up and NO MORE LEAKS! Not the OP's problem. Just mine.
