2014 210 leans when even ballast?
  • archcityblues
    • Aug 2013
    • 142
    • canada
    My boat leans to strbrd side when evenly weighted, full ballast. Tanks on both sides seem to be full. Anybody else find this?
  • KTM525
    • Oct 2007
    • 126
    • Switzerland
    • 2014 Nautique G21 ZR409
    1) Driver weight
    2) Prop torque when driving
    if the difference is bigger with full tanks, then i would check if everything is really full.
    • cedarcreek216
      • Oct 2009
      • 1009
      • Dallas, TX
      • 2018 210 2013 210 2009 216V
      Absolutely. When I pull my wife I fill the port tank about 3/4 full and the belly about 3/4 full and nothing in the starboard rear tank. Perfect on both sides.
      • SuperAirHokie
        • Apr 2015
        • 45
        • Lake Anna, VA
        • 2014 Super Air Nautique 210
        Cedarcreek - you set yourself up good on that one, but I am going to resist the temptation to spike it!
        As to the message, check tanks themselves (fill until overflow) as gauges aren't always accurate and factor in all weight in the boat.
        • nyryan2001
          • Mar 2013
          • 1993
          • Lake Anna
          Prop torque.
          1. Driver needs to lose weight
          2. Keep ~100-150lb lead on the port side to offset.
          2019 G23 450
          2014 G23 550
          2013 G23 450
          2011 Malibu Wakesetter 247
          2007 Yamaha AR210
          • swatguy
            • 1631
            • Midwest/ Northern IL
            • 2008 SANTE 210
            Cedars post was pretty funny.
            It's due to the prop torque. Even when weighted completely even while floating the boat will want to lean starboard. Grab some pop products or lead wake bags to throw on passenger side. My 08 does the same thing. I always fill so boat is leaning ever so slightly to passenger (port side)side while sitting still. The more aggressive prop you run the more weight you need to balance. Your situation is completely normal.
            • cedarcreek216
              • Oct 2009
              • 1009
              • Dallas, TX
              Touché. I can handle the sarcasm so don't hold back next time.
              • archcityblues
                • Aug 2013
                • 142
                • canada
                Checked tanks, they are completely full. I run them till overflow. Its even leaning when its just floating with nobody in the boat?? I guess its normal as I'm reading here. The weird part is that I don't think its always done it?? I could be mistaken and its not a huge lean, just seems odd..
                • lucky7t
                  • Mar 2011
                  • 1306
                  • Oklahoma
                  • 2015 SANTE
                  15 model same exact issue. I always fill port side up a tiny bit
                  Current Correct Craft Boat
                  Correct Craft Boats Owned
                  • NORRIS138
                    • May 2021
                    • 1
                    • Cincinnati Ohio
                    • 2017 G23
                    Great to find this thread. My 2017 G23 does exactly this!
