Need some help...my buddy is out at Havasu with is '14 G23 and the boat started loosing oil pressure then shut itself off and oil is everywhere in the engine bay...He was cruising at about 35mph. This warning message came up on the dash:
Any thoughts? Message says DTC 11 Intake Cam / distributor position error.
Motor is the CWS 450 HP Catanium CES by Crusader.
Thank you!
Thank you!
