LINC problem
  • josemolino
    • Feb 2011
    • 235
    • Barcelona Spain
    • 2014 G21 2007 SAN 220
    LINC problem
    Got some water in the batteries so we had to replace them. Since then, LINC screen shows NAUTIQUE but does not move forward to the menus. The engine starts but we cannot use any control/info from the LINC (speed, ballast,..)
    We have rebooted by dialing code+stop. Any ideas????
  • cmcmechan
    • May 2014
    • 24
    • Alberta Canada
    sounds like you had a voltage surge threw the system. Have the dealer try to reload the software. if that dose not work you are probably into a new LINC system
    • 81nautique
      • Feb 2006
      • 257
      • Big Rock, Illinois
      • 2012 200 Sport 1956 Correct Craft Collegian Past boats 1955 Correct Craft Hurricane 81 Anniversary Nautique 1960 GlassCraft Ski Nautique #1
      Sounds like you need to have it reflashed but being in Spain not sure that's as simple as running it down to your dealer. Contact Nautique and see if they can get you the current flash and you can do it yourself.
