2013 G23 - 550HP - I had the battery selector switch go bad. Simple replacement. Ever since I have been having a charging issue with the batteries. The batteries just slowly drain down to nothing while using the boat. I pulled the alternator and had it tested. Tested perfect. I had the batteries tested and they were fine, but I bought another set of brand new batteries just in case. I test the batteries with a voltmeter with engine off 12.2V. Start the engine and voltage stays the same or slowly goes down. I tested the terminals on the back of the battery selector switch and pretty much same readings. I have tried "1" "2" and "1+2" switch position with no difference. Its like there is no voltage getting from the alternator to the battery switch or the batteries. Is there some sort of fuseable link or something in between the alternator and the switch? I'm just at a loss. Most charging systems are basic and apparently I'm missing something so I'm looking for some help guys
