Help with diagnostic error message
  • iamcdn
    • Mar 2013
    • 337
    • Penticton, Canada
    • 2013 SANTE 210 with NSS
    We are on holidays and received this error through the linc system. Boat initially went into limp mode but returned to normal functioning after turning her off and back on. Any suggestions?
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    Overheat codes. I would check strainer,and raw water inlet under boat for blockage first.
    Sounds like your engine is not getting enough water for cooling
    1989 Sport Nautique
    • iamcdn
      • Mar 2013
      • 337
      • Penticton, Canada
      That is helpful. We have been renting a place in a channel with lots of weeds and a muddy bottom. I will dive under and check. I just changed the impeller so that should be good.
      • ScooterMcgavin
        • 1478
        • 2014 SAN 210 TE
        Any updates? How did the strainer look?
        1989 Sport Nautique
        • iamcdn
          • Mar 2013
          • 337
          • Penticton, Canada
          The strainer looked terrible. Quite clogged. It is clear and we will take her out today and see. Thx
