2008 SAN 210 motor wouldn't start
  • richardk
    • Jul 2012
    • 7
    • surrey, bc
    • 2008 210 super air nautique
    The push pad "start" button wouldn't start the engine. All of the gauges were working, fan, bilge were working too. Nothing happened when the start button was pushed.
    Had the boat towed to shore and next day day I looked under the dash at seems like fuses but they are not. Pushed on them and pushed the "kill" switch button a few times and tried the start button. Engine starts!
    Are the fuses under the dash "circuit breakers" or is it just a fluke it started and I have something more serious going on?
  • shag
    • 2217
    Should be circuit breakers. And did you check/jiggle the shifter? Sometimes the neutral safety switch can be the culprit... Maybe you pushed the right circuit breaker to reset.
    • richardk
      • Jul 2012
      • 7
      • surrey, bc
      I did see what looked like a fuse box under the dash and noticed "starter" . Pushed it a few times. Checked the shifter on the water. I think I pushed the right circuit breaker to reset. thanks...
