2003 TPS Fault - See Dealer
  • jaxnautique
    • Aug 2015
    • 6
    • JACKSONVILLE,FL
    • 2003 Air Nautique 210 Limited
    Need some advice. Few weekends ago I was out on my 2003 Ar Nautique 210 (5.7 engine) for an allday event. Never checked the the bildge or turned the bilge on to pump the water that was in the bildge. I was up on plane and headed back in and the boat became very sluggish and stalled out. Checked the engine compartment (V-drive) and noticed a fair amount of water on board. Pumped the water out and started the boat back up. Ran kind of sluggish but, seemed to be improving after a few minutes. The TPS Fault- See Dealer error came across the dispaly, I tried resetting it like the manual says, but the the error continues to keep coming up. So, I swapped the TPS Sensor with an AC Delco TPS sensor from autozone. Put the new TPS sensor in and still had the code coming up and the engine would idle at 1000rpm which was not normal. So I put the old TPS back on and still have the TPS Fault error. Please help me address the problem.
    Adam
  • Rockymtnsurfer
    • Nov 2017
    • 404
    • Steamboat Springs Colorado
    • 2003 210 SANTE
    Any luck with this?
    • Mccam1172
      • Aug 2016
      • 25
      • Algonquin, IL
      • 2015 SAN 210 95 SN “sold” wish i had not
      I think you have a Relearn procedure to do when installing a new tps sensor. Search the forum it has come up a few times. The idle will be off until the computer knows what closed throttle and wide open throttle are.
      • Rockymtnsurfer
        • Nov 2017
        • 404
        • 2003 210 SANTE
        Disappeared after and during the trip last weekend....works now
