My 2009 SANTE 230 has a high pitch noise coming from the engine compartment; I can't tell exactly where it is coming from. It seems to occur around certain RPMs and especially when I pull back on the throttle. As long as I am accelerating it doesn't really make the noise. The noise occurs in neutral at certain RPMs, as well. I have read about a whistle noise created by air intake, but this does not sound like something caused by this phenomenon. The boat runs well without any other issues; the sound is just annoying to me. I purchased the boat last summer and it has always made the noise. Any ideas?
Krustey....what will fix this is a spacer for under the throttle body. Had this sound with my 2010 226 343 and it took the sound away. There were several posts on this a few years back. Even a notice from PCM from what I remember. Mine purred like a kitten after the fix. No irritating whistle or whine...but still had good solid engine sound.
Originally posted by Kenv View PostKrustey....what will fix this is a spacer for under the throttle body. Had this sound with my 2010 226 343 and it took the sound away. There were several posts on this a few years back. Even a notice from PCM from what I remember. Mine purred like a kitten after the fix. No irritating whistle or whine...but still had good solid engine sound."I'm on a boat........"
Attached is a short video where you can hear the noise. I tried to accelerate and decelerate to show the sound.Attached Files
It's hard to tell from the video, but I had a similar sound on my '08 343. It wasn't there when I first took delivery...maybe a couple of years before I heard it. I contacted PCM to get the spacer plate but never got a response. In any event, based on previous posts here, it's normal--but you can reduce or eliminate the noise with a spacer.Last edited by xrichard; 08-13-2015, 08:54 AM.Previous boats:
2015 G23
2008 SAN 210
2002 XStar
1995 Sport Nautique
