replacing blower
  • dskier
    • 84
    • ohio
    • 2012 air/sport 200V 1999 ski nautique
    replacing blower
    On a 2012 sport 200V. Does the blower just "push" into the opening on the boat? I don't want to pull to hard if there is connection I am missing. There is a zip tie connecting the hose to the blower on the top but I can't tell/see any clamp or tie at the "bottom". I will send a picture if needed??
  • GC
    • Sep 2003
    • 54
    • Tampa, Fl
    There are two screws securing it in the bottom, probably hidden by the carpet.
    • NautiqueOasis
      • Oct 2005
      • 142
      • Dayton, OH
      • '13 200V Sport; '05 SV211; '97, '90 , '85 & '79 Sk
      I have a '13 200v and just replaced my blower; the 2 screws mounting the blower screw into the molded board in the transom. I secured both the top and bottom hoses with zip ties. I got my replacement blower from the dealer so it had the same electrical connection as the original blower (it was the same brand: Rule). I had a problem with an Attwood replacement blower that I replaced the original blower with last August; I kept getting a blower fault with my LINC system; Nautique thought the Attwood may be drawing different amps.
      '13 200V Sport Nautique
      '05 SV211 Nautique
      '97 Ski Nautique
      '90 Ski Nautique
      '85 Ski Nautique
      '79 Ski Nautique
      • dskier
        • 84
        • ohio
        Found them. Thanks!! Under the carpet like you said. I will get another Rule like suggested......
