08 210 lake water Temp gauge
  • Nautiquehunter
    • Jun 2008
    • 2080
    Any body know where the sending unit is for the lake water temp gauge. Mine is reading at least 20 degrees too high?
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    i have a 08 210 also. I am thinking we have the SN0015, although I ignore the paddle wheel based speed. You can call or email nautiqueparts and see what they say.
    http://www.planetnautique.com/vb5/fo...ge-calibration
    • Paxdad
      • Mar 2013
      • 775
      • Cumming, GA
      • 2008 210 SANTE
      I can confirm that the transducer is the sending unit for surface water temp.
      2008 210 SANTE
      • Nordicron
        • Sep 2009
        • 557
        • Madison, WI
        Anyone know where to buy a new transducer? I tried marineparts but they can't get anymore.
        • Aebert2668
          • Oct 2014
          • 49
          • Atlanta
          • 2006 SAN 220 2006 18' Hewes Redfisher 1979 16' Duracraft
          Boatersland.com and iMarineusa.com, part SN2060A for the SAN 2006 and I'm sure they used the sam part for the 08 SANTE. Easy to replace, running the wire is what takes the most time. Try not to run your transducer when the boat is out of the water, it can cause early wear. Good luck guys!
          • scottb7
            • Aug 2011
            • 2198
            I think 2060a is depth only...not water temp
            http://faria-instruments.com/product...dGauge=4_trans
            call nautique parts or faria and ask them what to do.
            • Aebert2668
              • Oct 2014
              • 49
              • Atlanta
              I stand corrected, scottb7 is right, looks like it should be SN0015, but probably safer to call. The temperature sensors on all transducers seem to wear out before the unit.
