Anyone have any recommendations on service and winterizing in the Denver area? I have a 2015 G23 that I would like to have service performed on, and has anybody gone through the "detox" invasive spray down that I am told I need to introduce the boat to CO waters? I am hearing that they spray the engine compartment with high pressure hot water? That can't be good for the engine can it? Any experience with this is appreciated!!! Thanks!
I had it done at Chatfield. It was a walk in the park. Hooked the hose up to the motor hose connection and ran there 140 degree warm water through it. They checked at the exhaust to see if it came out over 140. They sprayed the bilge down with 140 water. It is not high pressure by any means. You can easily make a hose at your house have more pressure. I don't have ballast so that could be a pita. Pm me if you want to talk on phone.
Winterizing I do myself but since it is a Nautique you might give the Nautique dealer a try. Action Watersports. Also John at Tommy's is a friend of mine he is trust worthy. Also Dave at Calibre is an excellent mechanic.
