2500
  • cmcmechan
    • May 2014
    • 24
    • Alberta Canada
    i have a 2004 ski nautique with a 330 exclabilier that will not go over 2500 RPM
    had a tune up done over winter
    disconnected perfect pass
    changed fuel filter
    was working great till last weekend
    looking for some help
    THANKS!!!
  • bscott
    • 188
    • Bolingbrook, IL
    Sounds like LIMP mode. I think the only two things that cause LIMP mode are temp and press, and I believe there are separate sensors for the gauges (at least there are on the GT-40). The sensors can go bad, so try disconnecting the sensors one at a time to see if the problem goes away.
    • Aebert2668
      • Oct 2014
      • 49
      • Atlanta
      • 2006 SAN 220 2006 18' Hewes Redfisher 1979 16' Duracraft
      I had a bad fuel gauge that put me into limp mode once, it was registering almost empty.
