I am not as experienced as I know some of you are, so I am going to let you guys take a look. I was doing my weekly walk around and when I went to check the prop I found that it would rotate slightly on the shaft. I went ahead and removed the cotter, castle nut, and the prop. I am going to order my new keyway today due to it having a little damage from prop movement, but I need to decide the nut issue. (insert nut joke here) I did a dry reseat on the prop with no pin to check the castle nut and it is positioned on the shaft at a place where it will need a washer between the prop and castle nut to function correctly. Question.... Stainless washer between the prop and castle nut so the pin is actually holding the castle, or make the move to the brass Nylock?
Thanks Guys..
Thanks Guys..
