Mounting heatcraft heater
  • phataz
    • Apr 2013
    • 129
    • hamilton, new zealand
    • 1999 super sport
    Hi Guys does anyone know if you can install the heatercraft heater upside down as i dont have a lot of room and the pipes coming out of the heater will be in the wrong place if i dont install that way. thanks
  • dan1166
    • 92
    Water flows in and water flows out. It does not matter which way it is mounted. As a matter of fact, my heater mounting brackets are made to mount either way. Hope this helps.
    Dan
    • jesutton3
      • Nov 2010
      • 93
      • Raleigh
      It can be mounted either way.
      But if it is mounted with the pipes up you will need to take extra care during winterization. It is harder to get all the water out with the pipes up.
      • phataz
        • Apr 2013
        • 129
        • 1999 super sport
        Sweet thank you for your help..... have you put one of the low idle things on WYE? just bought one on line the other day and its turned up but doesnt look right the hole in the small pipe where it goes back into the big part is small as like 5mm is this right to be that small?
        • jesutton3
          • Nov 2010
          • 93
          • Raleigh
          That is correct.
          • phataz
            • Apr 2013
            • 129
            • 1999 super sport
            thanks guys for your help as it is hard over here in New Zealand as there is not alot of people in the know not even the shop
