1995 sport nautique battery
  • brttkrz
    • Nov 2012
    • 62
    • MN
    • 1995 Sport Nautique
    What are you guys using for a battery in your sport nautique with the battery in the middle of the back seat? the dimensions are 11L x 7 W X 8H. the height is making it difficult to find a good battery. The other day when i was out the perfect pass went wacky and the voltage read low. I shut everything down and there was very minimal power but when i wiggled the terminals i would get some power but not full power and then every once in a while it would get full power for a second then when I went to start it it wouldn't have power. This went on for some time and we were emptying the water out of the ballast sac so we could get at the battery and the power was low. When we looked at the battery the amp cables were loose but the main terminals were well connected. Then all of a sudden it worked fine again and worked fine the rest of the night. Could this be a ground issue or becuase the amp cables were loose causing low voltage or a bad battery? Looking for a new battery and wanted some suggestions as the space for the battery does not allow for a 9in battery.
