Winterizing heater
  • Jeb1974
    • Jun 2013
    • 134
    • Calgary
    • 2019 G23 w/H6 2015 G23 w/ZR450
    Winterizing heater
    Is the heater on a G23 with the 450 part of the closed cooling system (and not need to be winterized?) I will be gone for a couple weeks and the forecast right now is saying it'll be getting close to freezing so I'm going to drain water from the engine. I've heard that heaters are more susceptible to freezing and cracking and didn't want to risk it if it needs to be blown out as well.
  • vision
    • 517
    • NC
    • 2013 G23
    Heater has anti freeze, not raw water, on the Gs with the 450.
    • Jeb1974
      • Jun 2013
      • 134
      • Calgary
      Great. Thanks.
      • Gbill
        • May 2015
        • 1
        • Calgary, Alberta
        • 2015 G21
        Does the 2015 G21 with a 409 have fresh water going through the heater or does the heater have anti freeze? Thank you.
        • Jeb1974
          • Jun 2013
          • 134
          • Calgary
          The water flow diagram in the pcm book is the same for the 409 and 450 so I assume it also has antifreeze going through it.
          • pinner99
            • Jun 2015
            • 63
            • Strathmore Alberta
            • 2017 G23
            Yes the 409 heater also has antifreeze running through it.
