Protec Ignition
  • cjtpilot
    • Apr 2015
    • 54
    • South of Atlanta, GA
    • currently boat less but looking
    Protec Ignition
    What years did the PCM come with Protec Ignition? Did Nautique have that on their PCM's?
  • Quinner
    • 2246
    • Correct Crafts
    On Correct Crafts, 91' thru 94' for sure, believe 95' as well. Fuel Injected versions were 94'-95' only IIRC, when the Pro-Tec goes on those it is a much bigger problem. To convert the Carb version it's about $500 for the kit.
    • Jonny Quest
      • Aug 2014
      • 383
      Quinner is correct: 91 thru 95. The Throttle-Body EFI came out in 94. When the Pro-Tech fails in the EFI boats, the easiest and least expensive option is to retro-fit back to carburetor & distributor. Old School.
      JQ
