OK, since the refineries are moving away from methyl tertiary-butyl ether (MTBE) and using ethanol in its place, what impact will that have on my PCM Excalibur 330? I thought that I had read that using ethanol was not recomended. If that is the case, then what are my options? Not use the boat. Try to find non E85 fuel, but where and how. Convert it to propane, I bet that would void the warranty.
What is your opinion, and what are you planning on doing?
Is anybody concerned that ethanol is so corrosive the refineries can't use the current pipeline distribution system, and it has to be trucked to the distribution center for blennding with gas?
