2002 SAN warning light
  • thorr
    • Nov 2013
    • 3
    • austin
    the warning light above the starter combination pad keeps blinking and beeping. says don't operate over 1200 RPM. i topped of engine oil (10w40), v-drive fluid (30 weight), and transmission fluid was fine....why would i be getting the warning that wont stop???
  • cmcmechan
    • May 2014
    • 24
    • Alberta Canada
    replace the pressure sensor on the port side of the v-drive.
    • jbach
      • Aug 2012
      • 187
      • the state, not the jelly
      • 1999 SAN
      i believe that it's a Hobb's switch, 5psi. you can find them a napa truck parts store, maybe the regular napa as well.
      • thorr
        • Nov 2013
        • 3
        • austin
        thx guys ..im a rookie at this...ive been looking for a Youtube for a video...is there one out there?? or at least more info regarding "how to"
        • thorr
          • Nov 2013
          • 3
          • austin
          i called NAPA...they only have a 4PSI or 10PSI...he wanted to know if the pressure sensor is "normally closed" or "normally open"...I believe the engine is the PCM 350...any advise?
          • cmcmechan
            • May 2014
            • 24
            • Alberta Canada
            i believe it is open when you unplug the wire the light will go out
            • jbach
              • Aug 2012
              • 187
              • 1999 SAN
              4lb, i'm almost certain it is normally closed, open breaks the connection for the light. you may ask over on correctcraftfan. those guys are great and extremely knowledgeable.
