hi, i have a super air nautique 220 (pcm engine) , 2007 that's not working good. i can turn it on but its not responding for the throttle command, even when i try to accelerate direct on the engine .the other problem is , when i turn the engine on i can hear a noise ( looks like the starter lose contact with the flywheel ). i already got 2 starters burned .
i think the problem is the flywheel . is it easy to change the ring gear flywheel ?
what do you think about the throttle problem ?
