2013 G23 Exhaust Manifold Water Temperature
  • davidmamato
    • Oct 2013
    • 44
    • westminster, ca
    2013 G23 with ZR450 and 400 hours "NEED HELP!" Boat goes into guardian mode with EMWT 1415 warning under LOAD! Here is what has been done so far: 1. Inspected water intake under boat- NO obstructions, 2. Inspected cartridge screen filter- NO obstructions, 3. Removed and inspected impeller- NO damage good condition, replaced with new impeller, 4. Inspected Exhaust Manifold Thermostat- No Damage, recently replaced less than 50 hours on new thermostat. 5. Used temperature gun to determine temperature of exhaust manifold when boat goes into guardian mode- 152 degrees F both manifolds. 6. Heat exchanger inspected- NO obstructions. 7. Coolant filled to specified level.
  • cmcmechan
    • May 2014
    • 24
    • Alberta Canada
    go threw and check all your hose clamps you may have a small air leek, causing a air pocket in the exhaust manifold thus throwing the over temp code
    • davidmamato
      • Oct 2013
      • 44
      • westminster, ca
      Ok, will check all hose clamps, thanks cmcmechan
