I have a 98 air nautique gt40 EFI and I am not getting power to the low pressure fuel pump. I replaced the pump today thinking it was a bad pump. I removed the fuel line to the FCC and noticed no fuel coming out. Afterwards I checked and had no power to the fuel pump, I'm not hearing the priming of the pump either. I also checked it with a tester. I also replaced relays and jumped the relays also to see if they were maybe bad as well. I hear the clicking of the relay but no priming at the pump. I also checked the negative cable at the battery and it seems fine as well. I've been reading a few posts here today but can't seem to find any additional possibilities. Please.....Anyone's help will be greatly appreciated.
This happened after a few weeks of bad rain down here in s florida where it's kept me from going on the lake. A few times while I was out this summer it did stall out on me as I was cruising. After letting it rest a few minutes it would start right up (if I tried to start it right away it would just turn over but not start)... That's what made me think it was the low pressure pump. Thx again...
