Spark Plug Torque
  • tlwolf
    • Apr 2012
    • 21
    • Rochester NY
    • 2011 200OB Team
    Spark Plug Torque
    What is the torque specification for installing spark plugs in a 2011 PCM EX 343 engine? I have found 8 -12 ft lbs on internet but can't definitive answer.
  • Paxdad
    • Mar 2013
    • 775
    • Cumming, GA
    • 2008 210 SANTE
    25 ft/lb
    2008 210 SANTE
    • tlwolf
      • Apr 2012
      • 21
      • Rochester NY
      • 2011 200OB Team
      Thanks.
      Is that in the manual someplace and I just can't find it?
      • jhersey29
        • Nov 2013
        • 330
        • Colorado
        It's a Chevy. Look up Chevy small block 350 torque specs.
        • Paxdad
          • Mar 2013
          • 775
          • Cumming, GA
          • 2008 210 SANTE
          Exactly what jhersey stated. The 343 does not have aluminum heads and I believe the plugs have a gasket on them and are not the taper version. In either event 25 ft/lb or even 3/8 of a turn past where the plug seats against the head is the specification.
          2008 210 SANTE
          • tlwolf
            • Apr 2012
            • 21
            • Rochester NY
            • 2011 200OB Team
            My 2011 PCM EX 343 engine has tapered plugs, no gasket. I think that changes the torque spec
            • Paxdad
              • Mar 2013
              • 775
              • Cumming, GA
              • 2008 210 SANTE
              10-20 ft lbs for iron heads.
              2008 210 SANTE
              • JayG80
                • Dec 2006
                • 206
                • Santa Fe, TX
                • 2007 Ski Nautique Sold 2002 Ski Nautique
                Do you reduce the torque 25% if an anti seize is used?
                AC Delco plugs have a rebate going up to Sept 30, 2021. Rock Auto.com price for plugs was $40 net after rebate.
                • SilentSeven
                  • Feb 2014
                  • 1854
                  • Bellevue WA
                  • 2004 Nautique 206
                  Originally posted by JayG80 View Post
                  AC Delco plugs have a rebate going up to Sept 30, 2021..
                  Ah...thanks for this. Just bought some 41-101's. $24 back...not too bad. Link to the form.
                  https://www.acdelco.com/content/dam/...ebate-form.pdf
                  Bellevue WA
