Fuel Filter Change Frequency
  • tlwolf
    • Apr 2012
    • 21
    • Rochester NY
    • 2011 200OB Team
    How frequently do you change the primary and FCC fuel filters if there are no symptoms? Manual says annually but whenever I change them the old ones look just like the new ones. Not at all dirty. Gas comes from a reliable supplier. 2011 PCM EX 343 engine.
  • Quinner
    • 2246
    • Correct Crafts
    Have always pushed 3 yrs or 150hrs on FCC. Write the hrs/date at last change on the oil filter along with the oil change hrs for quick reference.
    • scottb7
      • Aug 2011
      • 2198
      • Carson City, Nevada
      I have had my boat about 3 years....I am done changing it every year. I am going to go every 2 or maybe 3 years. It just does not get that dirty. I will change the little one once a year. Honestly, we will never know. But I bet if you changed the little one every hundred hours you could change the fcc every 300 hours.
      • Paxdad
        • Mar 2013
        • 775
        • Cumming, GA
        • 2008 210 SANTE
        Scottb, I agree with you. I actually dried my small filter out and cut it open this spring and it was fine. There was some small sediment/ particles present but nothing of concern.
        2008 210 SANTE
        • tlwolf
          • Apr 2012
          • 21
          • Rochester NY
          • 2011 200OB Team
          I also have cut both filters open and found no sediment or even discoloration. That's why I posted the question.
          • countiemountie
            • Aug 2006
            • 63
            • Kalkaska and SE MI
            • 2024 GS22
            I was talking to a looong time promo owner / world renowned coach about this very question. He stated he changes out the small fuel filter as recommended and lets the FCC go a bit. This coming from a guy that puts HUNDREDS of hours on his boats.
            I change my FCC out every 3 seasons with the impeller. The in-line fuel filter and oil get every season. I should also add that I don't put on much more than 50 hours a year.
