bolts are starting to fall out of my trailers bunks and I had an idea I wonder if anyone has tried. What if I get two 1x6 boards and glue them together with stainless bolts sandwiched in the middle? That way I could set them on the trailer and put nuts on from the under side and hopefully have less problem with rot. Thoughts?
I would not do this. If the bolt heads spin either during installation, repair or removal you are going to have to cut them off. Countersinking is the best.2018 200 Team H6
2009 196 Team ZR 409
2005 196 Limited ZR 375
2003 196 Limited Excalibur
1999 196 Masters Edition
1987 ProStar 190
I thought of countersinking, but I worry that water would be trapped on that would rot it out. Do you do anything like put caulk on the bolt head after countersinking it? I know its going to last for at least few years, but would like to make it as permanent as possible. I use my boat often and keep it on the trailer, so I'm looking for something good. I'm also adding swivel brackets to the top of the current welded on bunk mounts so that the boards can turn to fit flat against the hull.Ken
2001 DD Air GT40
