I just bought a 02 san with a ramlin trailer. Brakes don't work. Had no brake fluid and reservoir was rusty. I blew out lines and had every thing clear except reverse lockout. Reassembled bypassing reverse lockout but still no brakes. So where can I buy parts? Has disk brakes.
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
White Lake Marine is a Ram-Lin dealer. I am sure they can get the parts you need if necessary.
910.247.6201I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Item Part No. Options Unit Price Quantity Price The Vault Trailer Wheel Bearing Protector, 1.980 UFP07502 $11.95 4 $47.80 Trailer Buddy Hybrid Oil for VAULT Hubs, 14oz. U-VHLS14 $8.99 3 $26.97
UFP DB-35 Disc Brake Unit - Silver Zinc Plated Rotors w/Aluminum Calipers UKIT25 $264.95 2 $529.90
I order this from Pacifictrailers.com. I don't know if you have the same calipers and rotors, but they had Kodiak and a few other types too. The kits came with all the bearings and seals too. I later ordered the master brake cylinder after seeing some of the corrosion that had accumulated in the bottom too.
02 ramlin is going to have drums. The cc/ramlins I have maintained use many of the same brake parts (minus coupler) from '88 through '99. Parts are readily available from places like Etrailer. Post a few pics of your hub/drum assemblies and take a few measurements, should be 12x2" hub/drums. Several backing plate/brake assy options in that size, I suspect the originals were dexters, at least on the pre-torsion ez lube axles.1990 Ski Nautique
NWCT
