Dexron III vs Dexron VI Trans Fluid
  • Lakejackson
    • May 2012
    • 160
    • Lake
    • 2011 Sport 200
    Is Dexron III still readily available? Went to Autozone and everything was Dexron VI. Says it exceeds Dexron III, but I'm hesitant to use it.
  • Quinner
    • 2245
    • Correct Crafts
    That or Dexmerc will also work, as long as it meets or exceeds the requirement you will be fine. Just be sure NOT to use synthetic.
    • xrichard
      • Aug 2008
      • 667
      • El Dorado Hills
      • 2023 G23
      DexMerc is the same thing with a different label. Dexron is a trademarked name owned by GM and GM no longer licenses Dexron III name. I was paranoid, so I called PCM years ago and they confirmed DexMerc is what I should use.
      Previous boats:
      2015 G23
      2008 SAN 210
      2002 XStar
      1995 Sport Nautique
      • Lakejackson
        • May 2012
        • 160
        • Lake
        • 2011 Sport 200
        Thanks guys
        • countiemountie
          • Aug 2006
          • 63
          • Kalkaska and SE MI
          • 2024 GS22
          So no Royal Purple???? Uh oh.....
