I went out for first time of year and knock sensor warning indicator came on (04 sv211 w/ 330 excaliber) after about an hour of running. Anyone know what this is? Owners manual says "see dealer." Safe to run?
The knock sensor is in one of the block drain holes. It is extremely important to tighten the knock sensor to precisely 15 ft. lbs. or it will put the boat into limp mode.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Check and make sure it is connected, it is on the port side of the block near the starter. Possibly left disconnected when the boat was winterized. You will need to have the code cleared with a computer by the dealer to erase the code.
