Engine Oil 2002 Super Air
  • rman56
    • Mar 2009
    • 394
    • Kansas
    • 2002 SANTE
    Getting ready to do a service on the engine and tranny and I was curious what's a good recommendation of oil to use? We just bought the boat a couple months ago and I wanted to do a basic service on it any other things I should check or change?
  • Quinner
    • 2246
    • Correct Crafts
    Start by checking what engine, proper oil could vary depending on what you have.
    • rman56
      • Mar 2009
      • 394
      • Kansas
      • 2002 SANTE
      We have the Ford GT40.
      • Tjca77
        • Aug 2013
        • 58
        • Atlanta
        • 2000 Air Nautique
        Valvoline VR1 straight 40. You want the high zinc content for the GT 40.
        Sent from my HTC6435LVW using Tapatalk
        • Quinner
          • 2246
          • Correct Crafts
          Flat tappet GT-40 needs the ZDDP as mentioned above. You should spend a bit of time searching the oil topic here and on CCFan, quite a bit of good info out there.
          Valvoline VR1 is a good oil for your motor, some guys prefer 20W-50 over the straight weight.
          • rman56
            • Mar 2009
            • 394
            • Kansas
            • 2002 SANTE
            I used the Ford Racing Racing 20w-50 in our 83 Nautique. Is there a advantage with straight weight? I was told in the v-drive to use a 30W and dextron 3 in the trans.
            • Tjca77
              • Aug 2013
              • 58
              • Atlanta
              • 2000 Air Nautique
              The owners manual for my 2000 air dd says to run straight 40, that's why I use it. I'd be interested to hear why some choose 20w 50 instead.
              • rossrips7
                • Feb 2010
                • 233
                I second the VR1 in the gt40, i have an 02san as well. The book calls for straight 40 but depending on your climate the 20-50 works also
                • rman56
                  • Mar 2009
                  • 394
                  • Kansas
                  • 2002 SANTE
                  • rman56
                    • Mar 2009
                    • 394
                    • Kansas
                    • 2002 SANTE
                    I have always used a Fram filter on my other boat, is that still a good way to go on our 02?
                    • Quinner
                      • 2246
                      • Correct Crafts
                      Filter quality is very important - use a Motorcraft, Wix or Napa Gold.
                      Fram tested as total garbage in most independent tests I read. Recently saw testing that they did better in however I would still avoid their basic filters.
                      ​Whenever possible, fill the filter with fresh oil before installing, partially is OK also if that is all you can do.
                      ​And always double check the old filter gasket came off with the old filter. Write your hours and date on the new filter for quick reference.
                      • rman56
                        • Mar 2009
                        • 394
                        • Kansas
                        • 2002 SANTE
                        Thanks, I think I will go with the Motorcraft.
                        • rman56
                          • Mar 2009
                          • 394
                          • Kansas
                          • 2002 SANTE
                          On the 30W V-drive oil should I use detergent or non detergent?
