It's in storage, so I can't check the number on it, so can anyone point me in the direction of what stock alternator to buy for it?? I looked on nautiqueparts.com and came up with item number RA097006. Is that the correct one or can anyone suggest another one and where to get it? Not much of a engine guy, so I wasn't sure if I could go to local Napa and buy one. Any info would help, thanks
No, don't go to Napa. For the alternator especially, it MUST be a marine part. Anything else is not safe in an enclosed engine compartment.
This is the one you need.
http://www.nautiqueparts.com/alternatorpre-2003.aspx
Use discount code PND for 10% off.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Quinner makes a good point, and he has upgraded his sound system significantly. Amps draw Amps as they say. If you want to see a thread that shows you the clear path to a 100A alternator suitable for marine applications (explosion proof) check this link out;
http://www.planetnautique.com/vb5/fo...amp-alternator
Sent from my iPad using PLANETNAUTIQUE mobile app
