2002 Air Nautique
  • phantom driver
    • Mar 2016
    • 4
    • Birmingham AL
    • 2002 Air Nautque
    2002 Air Nautique
    Boat list to starboard side---no water in tanks --no water in hull--also sits on lift the same way. Appears it must be heavier on this side. Repair people say motor is offset 1 inch to starboard side and there is more bracing , cables etc. on starboard side. Anyone have an ideas why it might be doing this? Just bought this boat.
  • nukemustang
    • Sep 2014
    • 410
    • Summerville, SC
    • Current Boat: 2018 GS20
    Just curious, how are you verifying the no water in the tanks? Gauges? Visual?
    • phantom driver
      • Mar 2016
      • 4
      • Birmingham AL
      • 2002 Air Nautque
      Visual
      • Quinner
        • 2246
        • Correct Crafts
        The helm and all associated likely puts a bit more weight on the starboard side however the right rotation of the prop should offset that, are you seeing a list while underway also?
        Motor should be aligned with the shaft which should be in the center of the boat, did they check the alignment?
        • phantom driver
          • Mar 2016
          • 4
          • Birmingham AL
          • 2002 Air Nautque
          it does it while underway---it has a 3 blade prop and someone told me it should be a 4 blade? don't know if that would make any difference. They were not working today so I could not ask about the alignment.
          • Quinner
            • 2246
            • Correct Crafts
            Not true on prop, originally likely was fitted with a 4 blade however certain size 3 blades would be a good alternative for your boat depending on use. See if you can read any numbers on the prop to determine what size/pitch it actually is. If slight list while underway with just a driver that could be normal particularly if the driver is heavier in weight otherwise sounds like you have a weight problem, ballast as mentioned or is there maybe some hidden lead or something.
            • nukemustang
              • Sep 2014
              • 410
              • Summerville, SC
              I'm not 100% familiar, but do these hulls have foam chambers that can become waterlogged? I know the boat has no wood, but if it had a leak and the water saturated the foam for long periods is that a possible cause?
              • ScooterMcgavin
                • 1515
                • 2014 SAN 210 TE
                How does it sit in the water while not in motion. Still list to starboard side?
                1989 Sport Nautique
                • phantom driver
                  • Mar 2016
                  • 4
                  • Birmingham AL
                  • 2002 Air Nautque
                  yes it does
